Washing Machines Logo
Posted on Apr 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE model WHDVH626FWW Front load washer won't run, can't open door
The washing machine was humming when I went to transfer the load to the dryer. The only display was - door locked. Pushing the button did not open the door. I pulled the electrical cord to stop the power. I then replaced the plug and turned the power back on but only got the same hum with the same display and still cannot get the wet clothing out of the machine. I can't contact GE until Monday and online I couldn't schedule a service call until a week from Monday, May 5, 2009. Is there any way I can get the door opened? I am worried my clothes will be ruined if I have to wait 9 days for service.
  • josephine_ca Apr 26, 2009
    Thank you for your help. I was able to unplug and plug in the electrical cord and turn the dial repeated times until the door finally unlocked. I have removed the clothes, rinsed, hand wringing them and am now drying them. The tub does have water in it and you are probably correct that the pump is not working but being a 72 year old arthritic lady, I am unable to clean the clogged pump. I can't even remove the lower cover. I will contact GE for service tomorrow as I have an extended warranty.
    Thanks again!
Anonymous
Level 2:
  • Expert 240 Answers
  • Posted on Apr 26, 2009
Anonymous
Expert
Level 2:
Answers
240
Questions
Helped
107910
Points
555
Your drain pump is likely clogged,and is equipped with a clean out port. remove lower cover by 3 phillips screws on bottom front. you see the drain pump up front to the right. If there is a lot of water left in machine then have bucket/pan avail and plenty of towels. wet dry shop vac helps. you can open door and remove clothes from here. reach up on right side to where the latch is on inside (you have to go by feel) and find small round pull tab on bottom of latch/lock asm, and pull down, this will unlock door. carefull of water level when opening door.
to fix problem, unscrew cap on pump asm. water will pour out, and a tray will slide out with debris clogging pump. look inside housing for remaining ****. using finger check impeller area on right..
reassemble. machine should work perfect now. Pump is designed to be cleaned out and will not void warranty. newer machines have access port cut in panel for this clean out area.
2helpful
2answers
GE front load washer wont start model #WHDVH626FWW
there is a chance that your door lock has failed
3helpful
My GE front load washer model # WHDVH626fww wont run . The display works the door is shut the water is on but it just beeps when you pres the start button
we had that same problem too with a few others, had repair guy come out and all he had to do was cean out the drain that is behind the bottom panelof the washer, as you look at washer you will have 3 screws to take out and panel will come off, drain plug is on right side you can't miis it. make sure you have pan for water. clean it and it should help. it worked with ours.
good luck.
it cost us 121 dollars for that
Washing machine won't turn back and forth
Most likely your drive belt has slipped off. Open up the back of teh washer and see if the drive belt has slipped off and ease it back on with a screwdriver.
Door wont lock
I solved my own problem...
The machine stopped due to either a heavy load or clogged drain. I cleaned the drain (by taking pannel off the front of the machine). Then, the machine wouldn't cycle and it said "door locked" but the door wasn't locked. Basically, you have to let the machine finish a complete cycle (whether or not it actually does anything). Every time the start/pause button flashes, push it to have the machine try to start. This will eat away at the time. Eventually it will finish the cycle and say 0:00. Now it should run. This can take up to 2 hours so be patient!
GE ELECTRIC DRYER - WILL NOT COME ON.
Very often the problem is the resetable thermostat, if you open the top you'll find it on the back inside, you can test with an ohm meter or just bypass it to test it.
1helpful
I need a door boot for age washer model whdvh626fww
just enter the model number and the brand in the following link and you can choose any spare part for your model.all the best.
www.espares.co.uk
2answers
Ge adora whdvh626fww not filling with water and locks door
Can you take a look at the pump to see check why it is able to pump-in water ? Motor is still good as you can hear it trying to pump-in water.
Humming and not filling?
had the same problem this morning, turned out the pump on the drain side had frozen, took it apart, and broke free the fan, humming stopped, washer back up and working.  Its two screws to the bottom of the washer, two electrical connection (white and black) two hoses to undo, and three screws on the pump itself, after actually committing to doing it, only took about 10 minutes.
good luck
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
