Friend, if it is sim card rejected it means two reason. 1. the sim card is damage. replace it.
2. if the sim card is dirty,clean it with a pencil eraser.or if the sim
connector of the phone is loosen firmly connect.be sure the sim card is
connected firmly to the sim card connector reader. failure of these may
cause such problem,good luck
SOURCE: sim card rejected / insert sim card
SIM card rejected means the SIM card has failed, it needs to be replaced.
Best of Luck.
SOURCE: MY NOKIA 6300 IS SAYING 'NO SIM CARD INSERTED', BUT THE SIM CARD IS INSERTED. WHAT CAN I DO?
no problem.. jus remove your sim card and reinsert it. .sometime it may happen like this..
You need to do some testing first.
Put your sim card on another phone (should be unlocked or the same provider) and see it it works.
Put another sim card on your phone (should be the same provider sim) and see if it works.
From there you can check where the problem lies.
my phone says smart chip registration failed?? what should i do
as above
