SOURCE: washing machine not spinning or draining water
its your drain pump if you can hear it humming but no water is draining it is blocked or jammed by a foriegn object (most probably a 20 cent coin or bobby pin/s), if you can hear it working as normal but still no water it may have a blockage sumwhere along the drain pipe either that or the impellor has snapped off the shaft and is ratteling around and not actually turning, and with the spin that is directly related to yor drain pump issue as the washer will not even attempt to spin if water remains in the tub, incredibly easy to do hit me back if you want detailed instructions
SOURCE: LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
