Since ' 05 this one IS - LCDTV32 working as it need to be - nothing wrong. Untill one day it freeze in VGA mode. Only " power on/off" button at the remote working - but when another buttons on the remote pressed - blu light indicator at the TV start blinking - mean, signal is coming from remote to TV - but no reaction on TV. Same story about the buttons from back TV - only power on/off working.
LCD panel is Sharp brand.
Thank you.
SOURCE: Insignia IS-LCDTV32 32" Wont let me change channels or go to menu
there is a problwm wit hyour mainboard you can buy one on ebay for about $80 and to remove just take off back panel and unplug about 5 wires and remove 2-3 screws on the left side / the same side that your power ch+/- ect is on. and swap out.
please rate my answer it is much apreceated
SOURCE: Insignia TV is acting wierd
the problem lies in themain board in the tv. you can buy one from ebay for around $80 used. its not to bad to replace either. just remove the back panel the main board it the tin/ metal wit hthe ciruit board in it on the left side same side as the power botton just unplug the 5-7 wires and unscrew the 2-3 screws and carfully side that board out and replace with a new workign one and put back together and you should be good to go.
SOURCE: insignia is-lcdtv26 26", NO SIGNAL
This TV (Insignia) has been recalled (Model # : IS-LCDTV26) - Best Buy AS OF 04/02/2009 is STILL holding recalls for this TV due to fire hazards & power supply failure - the official report is here ->
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09183.html
Contact best buy's customer care hotline @ 800-233-0462 to get a gift card for upto $800 if you own this TV (Insignia - Model No. IS-LCDTV26)
SOURCE: The Insignia LCD tv shwos no signal?
Using the function button or source button on the remote switch to TV mode. that should do it.
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
easy...huh
if your a smoker...you must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
TRY TO STOP SMOKING...
