use old battery first try to boot
if your system is boot run bios update from intel.com
then change new battery
else run bios flash from chip level service provider
Most important, check with Intel's support site to see if you have the latest version of the BIOS.
Boot to the BIOS: Choose "Configuration", then "Video", choose "Enable if Primary" or if you're feeling brave choose to Disable it entirely. WARNING: DON'T do this until your other card is working properly! You've been warned!
While still in BIOS: Choose "Configuration", then "Video", choose "AGP" if available, or "Auto" if AGP is not an option.
its problem bios not configure properly reset mother board jumpure 1-2 normal 2-3 reset again position 1-2 machin is on press F2 set up bios your choice configure before unpluged your hard drive
Ok, Pop the disk in the drive and make sure the disk is clean. Restart the PC and go into the bios, set the bios to defaults, hit F10, save the changes and exit the bios, the computer will restart and hopefully boot from the DVD.
PUT YOUR OLD COMP BACK THE WAY IT WAS .IF IT BOOTS AS ALWAYS,GO TO CONTROL PANEL.SELECT "SYSTEM",SELECT DEVICE MGR,SELECT DISK DRIVES.RIGHT CLICK ON YOUR SLAVE,SELECT UNINSTALL,FOLLOW INSTRUCTS.TURN OFF COMP AND REMOVE YOUR SLAVE.REBOOT.HOPE IT WORKS FOR YOU!
