SOURCE: Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
SOURCE: CONNECTING MY TV TO MY STEREO
Make sure the output in your tv menu is set to external speakers. Any digital optical cable, or RCA jacks hooked up properly from the TV's out put to the receivers input should work just fine. Take your time, retrace your steps, and make sure each cable is in the correct input/output. And make sure the receiver and TV are on the proper settings. Good Luck, and thanks for using FixYa!
SOURCE: Purchased Technics Digital Surround Processor SH-AC500D
I have one and can make a copy of the manual if you would like. You would just have to pay for postage. Please let me know if you are interested. You can email me at [email protected].
Thanks.
Ed
SOURCE: My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
