Make sure you are on the correct channel thats tuned in, that the connections between the console and the tv are all seated firmly and make sure there are no bent pins or anything like that if any of the connectors have pins also what connector type are you using ? HDMI if so try a different hdmi port on your tv ?
Okay, I have noooo idea what's happening...My PS3 was working perfectly fine a couple days ago, and now, it has a weird issue...When I turn it on, it looks fine(sometimes, nothing shows up), and then, when I play music, movies, view pictures, or even play games, and go on the internet, the screen gets pixelated, then green squares start appearing out of nowhere, the system freezes, and everything is useless. I've heard this issue with HD, but I'm using standard def, and I've tried everything short of taking the thing apart. Is there anything I should, or CAN do? Or should I just say "screw it", and give it to games stop?
