Fisher Paykel Eco IWL16 Logo
David Tasciotti Posted on Oct 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Machine will not power on. - Fisher Paykel Eco IWL16
Brian Coughlan
Level 2:
Champion:
  • Expert 280 Answers
  • Posted on Nov 21, 2013
Brian Coughlan
Expert
Level 2:
Champion:
Answers
280
Questions
0
Helped
87056
Points
430
If the display lights do not come on at all then more than likely the Motor Control Board is dead, a replacement can be expensive so if your machine is over 5 years old think about replacing it. Remember you get 2 years warrany on all F&P machines. Most importantly make sure you are getting power to the machine by trying something else is the power outlet like a hair dryer.
I was using my Janome 1600p with the surestitch regulatr .I was practicing since it is new,with no problems.Shut the machine and regulator off for approx. 1 hr,and it would not work at all.
You tried disconnecting the stitch regulator?
No, try machine without regulator.
Yes, make sure you have power at the wall socket. Unplug sewing machine and plug in a lamp, radio, or vacuum to test for power. If power at wall socket, then plug sewing machine back in to wall socket. If still no power, disconnect and reconnect power cord at machine end. If still no power, try cycling the sewing machine ON/OFF switch a few times.
If still no power then likely the internal fuse or other.
https://www.manualslib.com/manual/1231564/Janome-1600p.html?page=16#manual
Frequently power down
1. Power off the printer and computer and then disconnect the interface cable.
2. Power the computer back on.
3. Once the computer has booted, power the Brother machine back on.
- If the computer still reboots, restarts, shuts down, or enters hibernation mode, this problem is related to the power source for the Brother machine and computer. Continue to the next step.
4. If the Brother machine and computer are plugged into the same surge protector, uninterruptible power supply, or power backup device, power everything off.
5. Unplug the Brother machine power cord from the power device.
6. Plug the Brother machine power cord directly into a wall outlet or a different surge protector strip. You may need to use the reset button on the power device.
7. Power the Brother machine and computer back on.
Still having Problem Then follow Us For Brother Printer Support
MFC-8710DW has no power
If your Brother machine does not appear to have power,then check whether or not the date and time appear on your Brother machine's LCD. If anything is displayed on your Brother machine's LCD, then it is most likely receiving power.If your Brother machine's LCD is blank, continue to Step 2.
Verify the Brother machine's power cord is connected securely to the power outlet. If you are using a surge protector, extension cord, or power switch, disconnect it and plug the Brother machine directly into the wall outlet.
Please note Brother strongly recommends that you connect your machine to a surge protector.Because To protect your investment against power surges and lightning,
In particular, we suggest that you use a surge protector that is compatible with both standard A.C. power cords and telephone line cords. Surge protectors equipped with telephone jacks will assist in insulating your machine from any power surge that might travel through a telephone line.
If the Brother machine is turned OFF, its LCD will be blank. Please make sure the Brother machine is powered ON by pressing and holding the On/Off or Power Save key. This key is located in the upper-right corner of the control panel.
If your Brother machine's LCD is still blank, connect it to a completely different, known working power outlet. If the Brother machine powers up, then the problem is related to the original outlet.
-OR-
Confirm the power outlet is working by plugging another known working device (a lamp, radio, etc.) directly into the same outlet. If the other device does not work, the problem is related to that power outlet. If a wall switch controls the outlet, verify that the switch is ON.
If your Brother machine still will not power on, please contact Brother Customer Service.
Or
Please Follow Us On Brother Printer Support
My Pfaff model 1211 machine won't come on. The power switch has been replaced but no light and no power for stitching
Sounds like a bad connection somewhere as the power seems intermittent. Consult your repair man to check the electrics.
2helpful
2answers
Machine has no power, it is plugged in and the fuse has been changed, there is power to the socket,
IF there is no power going to the machine.possible fuse not properly mounted.Try to check using a tester if power is flowing to machine.From the socket,use an extension wire and check if power is flowing within the circuit if it is the problem is in the machine.Did the machine blown out?
Describe 102-372 code problem in m24 xerox work centre
Solution : Power OFF the Printer, Wait 45 Seconds, Then Power ON CAUTION: If the machine is powered OFF / powered ON, all information that is stored in the machine's memory may be erased.
NOTE: Before powering OFF, make sure that all copy or print jobs have completely finished. Never power OFF in the following instances:
  • While data is being received.
  • While jobs are being printed.
  • While jobs are being copied.
  • While a scan is being executed.
  1. Power OFF the machine. The power switch is located on the front right side of the machine under the Control Panel.
    NOTE: Before the machine is powered ON again make sure the Touch Screen is blank.
  2. Power ON the machine.
    NOTE: When the power is ON, a 'Please wait...' message will be displayed. This message indicates that the machine is warming up and cannot be used. After 45 seconds, the machine becomes ready for use.
    If the issue is not resolved repeat steps 1 and 2 a second time.
Can the HP 1040 fax be cleaned to remove the two vertical lines that print? How? There is no glass to be cleaned and it does seem that the machine can easily taken apart?
This seems to a hardware problem. Resetting the machine fixes it most of the time.
There are many levels in reset, please try the the next level if the 1st did not fix.
Power Drain:
* Turn OFF the machine, disconnect the power cable from backside of the machine and from wall outlet.
* Press and hold the Power button for 60 seconds.
* Connect the cable and turn ON the machine.
Partial Reset
* Remove the power cable from back side of the machine while its ON.
* Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
* If machine turns OFF, press power button to turn it ON.
Semi-Full reset
* Remove the ink cartridges.
* Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
* Insert the ink cartridges.
NVM Reset
* Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Riztech
1helpful
I live overseas, and brought this sewing machine
its not transformer or machine problem at all.all the connections are also proper.its the power issue the required power to the machine is not getting from the electric outlet.just call the local electrician and check out the power supply voltage from the electric outlet.and power required to the machine which will be listed on the machine.if more power is required he will connect the over power IC and get the machine work.if less power is required he will connect the RESISTOR and lower the power to the machine and make it work.
Top Fisher Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
