Re: how can i transfer the files from the pc to my mobile...
U can transfer the files using pc suite of your mobile it will be on the cd that came with the mobile.just install it and connect via cable or bluetooth.after connecting open your pc suite and have fun .thanks and take care of yourself
Hi,i think you need a detailed step by step guide to assist you with the task before you i.e transferring photos from you phone to your laptop.
Below is a detailed solution to your problem;
STEP 1.
Most mobile phones nowadays come standard with a USB data transfer cable and bundled software utility. Check the box that your mobile phone came with for the cable and CD-Rom. If not provided with the software, it may be available as a free download from the manufacturer’s website. STEP 2. Once you have located your software CD, check the system requirements necessary to run the software such as hardware specifications, operating systems supported etc. Install the software following on-screen instructions, but do not plug in the USB data cable or phone in just yet, unless the software requests you to do so during the installation process. STEP 3. Once the installation is complete, the software would usually require a reboot of the PC before plugging in the mobile phone for the first time. Then connect your mobile phone to the data, and the cable to the USB port of your PC. Several phones may display a message on the mobile display that the phone is now connected to the PC, but if not don’t worry just yet! STEP 4. Once connected, start up your mobile phone’s software, and browse through the interface. Most manufacturers offer some form of phone browser where you can browse through the content on your phone, copying files onto, or taking files off the mobile. The software utility may also offer a separate tool for transferring photos and video shot with your mobile, if this is the case use the utility! STEP 5 .Use the software’s browser or photo utility to transfer your photographs to your PC. Some software tools provide image editing tools as well that will enable cropping, rotation, and sharpening of images once transferred to you PC. Don’t be afraid of referring to the software’s help file incase you get stuck. The above guide will be of great help to you,as a note of warning;Remember never to unplug or disconnect the data cable from the phone during a data transfer or you could end up damaging your phone or loosing all your data. Thanks and take care
hi friend here are several ways to transfer mobile phone
photos onto your PC, ranging from, emailing them using GPRS, Bluetooth
file transfers, Infrared file transfer, using MMS service, using a card
reader or simply using a data cable. VideoJug themselves even have a
film on the subject, but this guide will address transferring
photographs to your PC using the manufacturer supplied data-cable and
software.
Step 1: Check To See If You Have The data Cable And SoftwareMost
may be available as a free download from the manufacturer’s website. If
your phone did not come with a data cable, check the manual if your
model supports data cable transfers.
Step 2: Install The Communication SoftwareOnce
Step 3: Connect Your Mobile Phone To The PC Using The Data CableOnce
worry just yet!
Remember
your data.
Step 4: Start Up The Software Package And Locate The Image Or File Transfer UtilityOnce
Step 5: Transfer Mobile Phone Photos Onto Your PCUse
As
phone models and manufacturers vary, it is always a good practice to
read through the mobile phone user manual and the software's help or
readme file while using this guide. It is also always good practice to
use the backup function of the software first to ensure you can restore
your phone back to its original state should anything happen to it.
If You have a software in your PC and you want it to move to your mobile follow these steps: Connect your mobile to your PC Via Connectivity Cable (it comes with your mobile set along with the required software and drivers for your mobile you are needed to install these drivers and software on your PC first your mobile also have a complete instructional manual that can guide you while connecting your mobile to your PC ). You can also connect your mobile your to your PC via Bluetooth (For this you need a Bluetooth enabled mobile and a bluetooth device for your PC). After connecting your mobile to your PC you'll able to transfer your files from PC to your Mobile and then you can load that software from your PC.
FOR A COMPLETE DETAILED GUIDE KINDLY POST YOUR MOBILE MAKER NAME AND MODEL NO.i.e. NOKIA N96
Thank you for further information please get back here or gimme a mail @ [email protected]
no need of installer !!!! do as follows
1. connect the data cable to your mobile
2.connect the other end of the data cable to your system
3.go to SETTING > CONNECTION > USB > FILE
TRANSFER
4. now ur mobile acts like a pen drive u can transfer files !!!!!!!!
a.copy paste the link in the browser b. since u have provided the model of your mobile i will provide the pc suite link,u search your mobile and your required language,then u can download the file to your PC. c.Install the Nokia PC suite to your PC
2.After installing the Nokia PC suite,check wither u are able to transfer the files form Mobile to PC and vice versa.
3.Even after u have installed the PC suite its not working check wither u have connected properly the USB cable from Mobile to PC
4.Still its not working,check wither its properly installed on your PC.
Hi Friend, Actually u can transfer directly from your Laptop to mobile around 10 mb.U can use the Nokia PC suite and transfer the files from PC to Laptop or Vice versa.
U can download the Nokia PC suite from the Below Link
Copy and paste the link in the browser and scroll down u will be able to see your model(Nokia 6300) download it and install it in your Notebook.
Then u can access mobile from your notebook with the help of datacable or bluetooth
After installing u will be getting a in the desktop as nokia pc suite double click it and connect the mobile as per the steps given over there (its user friendly).
Then u can access the mobile from Notebook and transfer the files.
try to remove the battery on your mobile and press and hold the power button for 10 secs. try to put in the battery. try to power it on. if it doesn't work try to ask your friends if they have an identical phone as what you have, try to borrow their battery. if it works then you need to replace the battery on your mobile.
I try this sms transfer days ago. It could save the sms to pc and restore back to your cell phone. It get the job done well. But it just support the phone running on Windows Mobile System. Here is the user guideline of the software. http://www.godswmobile.com/transfer-sms-from-windows-mobile-phone-to-pc.html
