GE DVLR223 Dryers Logo
C
Chris dibble Posted on Oct 22, 2013
My Hotpoint TVM570P is making a dreadful noise. Looked inside and cant decide if it is the drum bearing or motor bearing. When i spin the motor or drum separately without the belt on, they both seem to spin smoothly. If i put load on the drum shaft there is some noise but not as bad as when it is running. Any clues?
temetz3156
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Oct 23, 2013
temetz3156
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
12607
Points
12
Get a piece of hose and listen to each bearing. The hose should help isolate the problem.
5 Related Answers
Anonymous
  • 163 Answers
  • Posted on Jan 04, 2009
SOURCE: dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Anonymous
  • 50 Answers
  • Posted on Jan 25, 2009
SOURCE: dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Anonymous
  • 2992 Answers
  • Posted on May 30, 2009
SOURCE: cant get drive belt back in place
You might find this site helpful. Good pictures and a sense of humor!
Anonymous
  • Posted on Jan 03, 2010
SOURCE: Ge Adora Dryer, Worked great.
the dryer during its cycle squeaks and rumbles it sounds like some thing is not right.
Anonymous
  • Posted on May 25, 2010
SOURCE: Belt Not Tight
The belt gets tight when you press the pulley arm down place the belt over the outer edge of the pulley and then over the motor axis. The belt then runs like in a "eight". Christian
2answers
My Hotpoint vented tumble dryer Model number
tvm 570 bearings
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Aug 28, 2014 • Dryers
Smoke coming from inside drum after spin cycle
The noise would possibly indicate that your drum bearings are on their way out, this would more than likely mean a new spider assembly, tripod in shape and houses the bearings through the drum, as well. They come in kits or bearing assembly alone for various prices, usually around 40 pounds for the kit but it would be a very difficult job if you are not familiar with this type of work, bearing extractor kits are best used but more cost, drum seals may also be needed.
2helpful
Hotpoint Aquarius 1000 WM62 The drum makes a screeching noise when turning ? Any ideas ?
it could be drum bearings or even some thing that has got past the inner drum and is jamed inside hitting the drum when it turns,,,,could also be the motor bearings,,,,open the door and try lifting the inner drum up,,if there is any lift in it then the drum bearings are going,,this will also cause it to screem on spin speed
Final spinning cycle makes very loud noise.
sounds like you have the dreaded bad tub bearings. Does it sound like an aircraft taking off? Open the door and lift the drum and see if you feel any play.
I don't know your technical ability, but you can match up bearings and a seal and repair it ( frigidare will only sell you the complete drum with bearings) but its a big job as appliance work goes. You will have to decide how to proceed from there as far as fixing it or buying a new one.
Drum has stopped moving
Hello, these is usually the drive belt,the drive belt is the easiest parts to replace.
Thanks
Noise when agitateing wash only
Remove the belt, and spin drum by hand from inside, there should be little or no noise, if there is then it is possible the drum bearings are failing.
I f no noise, but there is when you put belt back on, then possibly bearing in motor noisy
1helpful
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
1helpful
Hotpoint WF220P has become very noisy during spin, especially at high revs. Can it be worn brushes or motor, or bearings? Otherwise all is OK.
Remove drive belt, and spin drum by hand, if it feels rough or noisy, then the main drum bearings are worn.
If no noise from drum, could be a motor prob.
Please rate ,my solution.
Thanks.
3answers
My Hotpoint WD860 makes a dreadful noise when it spins, but fine at all other times, any idea's?
Just put some grease at the bearings of the drum. This will correct the noise. However, if it persist, your bearing may need replacement.
6helpful
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
