Could be a number of things included but not limited to.....blade spindle bearings....idle pulley or engager pulley......could also have a bad spot in belt....causing a vibration. This vibration could also lead to deck coming out of level as that model have a leveling adjustment on the deck level control lever.
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: need parts for old murray rider mower 36 in
If you send me your email address I will send you a PDF file of the parts for your mower
m o w e r m a n 1 at h o t m a i l dot c o m
Use correct format and without the spaces
SOURCE: deck trouble with a murray 40: cut mower
A hanger may have come loose from the deck that needs to be reattached.
Plus check your tire pressure, one tire with less air than the other will make it cut lop sided.
SOURCE: how do i level the deck on a murray riding mower
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level
SOURCE: how to adjust the mower deck on my murray rider,
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
