Kodak EASYSHARE CW330 Digital Camera Logo
Posted on Sep 28, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New memory card
I bought a new 2GB memory card for my Kodak Easyshare CW330, I inserted the new memory card into the camera and tried to take a picture but it said the memory card was full, which I don't see as a possibility because I took the memory card out of the package less than 5 minutes before, how do i get it to work?
  • 4 more comments
  • mwboykin Jul 21, 2008
    my problem is the same as the one stated. I have tried everything but nothing works.
    I installes a new memory card in the camera, and it said,"Memory card full". Not possible. I have tried everything to no avail. I have reinserted it several times, removed and reinstalled the batteries, turned it on and off. Nothing works.
  • Lilashley91 Feb 06, 2009
    Reset what?
  • rthomas269 Feb 17, 2009
    I bought a new PNY 2 GB memory card for my Easy Share, and after inserting it the LCD screen reads 'Memory Card Full'. Tried again, same thing. Went thru manual, reformatted, same thing. Went and bought a Kodak 2GB SD High-Speed Card, same result. Called Kodak 800# and guy said they did not have my camera in database.
    What gives?
  • Anonymous Mar 16, 2014
    cannot retreive pictures from memory card camera will not work with a new card
Anonymous
Level 2:
Scholar:
  • Expert 151 Answers
  • Posted on Sep 28, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
151
Questions
0
Helped
41678
Points
277
Insert it again after resetting.
2answers
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Memory card says full when i put new sd 2gb card in card won't work on my kodak easyshare cw330 camera
I was checking to see if your camera had a limit to the size of SD memory card and couldn't find a thing so what I suspect is that the SD card lock has been engaged here is a diagram to show you how to unlock it.
Also any new memory card needs to be formatted in the camera before the camera can "read" it.
After pictures have been loaded to the memory card and then downloaded to the computer the memory card needs to be formatted to clean the old pictures off and make the memory card ready to accept new pictures.
Cannot format sandisc 2GB memory card in my Kodak easyshare CW330 camera. it says filesys error e00100
Use a card reader and format on a PC. When card is inserted go to my computer and the disc should be there, right click and go to format then proceed as per screen instruction.
Trying to insert new memory card and says memory full. When try to format it, says 00100 error. Kodak Easyshare CW330
The CW330 uses MMC and SD cards. Make sure you have one of those cards, 2GB or smaller, and not an SDHC card.
2answers
What is the largest SD card that is compatible with the Kodak Easy Share CW330?
This camera can hold up to 2 GIG of memory card that you can use for it.
EasyShare Z612 Digital Camera: I bought a new 8GB memory card for my kodak easysh...
The Z612 works with SD cards, which max out at 2GB. It will not work with larger SDHC cards.
2helpful
Say's the memory card is full. It is a new empty (kodak cw330)
You may need to go into the Menu Selection of the camera & locate the "Format" option. Choose Format & see if it will then read the card.
12helpful
Kodak easyshare cw330 new memory card reads full....
Camera doesn't support more than 1GB memory card, so better use less than 1gb SD card
..........Prashant
3helpful
New memory card says memory card full
The following memory cards are compatible with your Kodak EasyShare C330 Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your Kodak EasyShare C330 accepts SD Card cards.The largest SD Card card you can use in your Kodak EasyShare C330 is 1GB
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
