Yes your MFP has had a fuser reload error. It's not permanent though. Sometimes the thermistors don't read the right temperature due to the thermistor getting excess toner built up on it or it gets moved away from the hot roller. This SC error usually can be reset by powering down the printer. It must be powered down correctly or you can corrupt the hard drive.
Hold the power button down on the operation panel until the screen goes dark. Then, physically turn the power switch off on the side of the unit. Once the unit has completely powered down and all lights are off, toggle the power switch back on. The unit should power back up normally. If the SC 542 returns, you'll have to have a technician check the fuser out.
Thanks bro, it was very helpful.
From Copy screen reset 107 hold Stop/Clear
Add a Commentafter thath enter copy sp do a sp 7-807-1 # and reebot
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
SOURCE: I need the reset procedure
This is how you reset that error:
press the yellow "C" button
enter 107
press the red "C" button and keep it hold till the display changes
turn the power off with the big red switch on the unit
turn power on again
Thanks much - if somehow that doesnt work please reply.
Tim
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
