It may have something to do with the settings under audio output devices. See if you have options, and ensure that the headphone jack (I assume that's what you're using) is set as the default sound device.
SOURCE: when i plug an hdmi
Hi, When you use the HDMI you have to switch the TV to HDMI to make it work. Not the other way around. Select the menu on your TV click to HDMI 1 or 2 depending which you are using. Sometime you have to ignor what it says. Try it out any way. Good luck.
SOURCE: When i try to play my x box on my sanyo tv no sound comes out of the tv
Try a different HDMI input and a different cable.
DVI is same as HDMI in regards to the picture signal, but lacks the audio.
Apparently for some reason the TV does not pick up audio and that could be because the HDMI port has a problem (say physical contact) or because the cable has a problem or (of course) because the XBOX does not output signal for some reason.
My first two picks would be the port and the cable.
hope this helps!
www.coppelltvrepair.com
SOURCE: problem using Audio 3 sound inputs for HDMI video
Normally this problem is simply a matter of selecting the correct default audio playback device in the Windows control panel (sound option).
Check the Playback tab and set the default device to either DVI or HDMI.
http://pcaudiohelp.com/fix-hmdi-sound-to-tv
