Water heater not heating it's a richmond water heater
Water heater not heating it's a richmond water the oly numbers I know is 6E40 have all ready replaced heating element in it? what could be the problem?
I have the problem fixed found out that the lower element was out to, and that my husband wired the thermostat wrong! it'sworking find now thank you!I have the problem fixed found out that the lower element was out to, and that my husband wired the thermostat wrong! it'sworking find now thank you!
Computer keeps resetting to vacation modeComputer keeps resetting to vacation mode
AnonymousMar 13, 2014
Boost button will not heat water, If you program NLE7 unit to come on during night time water heats up fine.Try it during the day still no water.Is the timer at fault or could it be one of the elements.Boost button will not heat water, If you program NLE7 unit to come on during night time water heats up fine.Try
You can't post conmments that contain an email address.
The pilot lights then heats/sends a signal to open gas for burner then(burner)should stay on but if valve shuts the gas off,then have your unit checked. What ever you do,DON'T MESS WITH IT IF GAS/FLAME ON!!!!!. These systems come with a safety feature that allows gas to go on only when safe!!!!
1) My search does not show that product exists, or existed before the internet. Maybe that product only exists on fixya. Or the water heater is older model number from Rheem., aka Richmond, Ruud etc. Or fixya picked up a model number from a question, and the person asking question did not copy model number correctly from label on side of tank. It might also be older manufactured home gas water heater.
Start-point is to inspect and clean burner parts and combustion chamber, clean air intake, bleed air out of gas line, test gas pressure, test electronic gas control valve, check for venting issues. As general rule, gas water heater manuals recommend professional service once a year that would cover most items listed above. To see images, and for more reading and resources, look at your product manual and open following link: http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Get ready to replace. I have been notified of this problem about 30 times and each time the water heater dropped its load within 10 days. I was always replacing water heaters.
BUT if it is the pressure valve that is leaking then that alone can be replaced. That prevents the heater from blowing up.
okay know that upper heating element and themastate was just replaced and it still is not heating? what else could it be? please help!
well I had changed the thermostat when I did the upper heating element, and it still isn't heating up! so now what?
