SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
SOURCE: ricoh aficio 1035 sc code sc 329 troubleshooting
Laser diode beam not positioned correctly. Turn the machine off and back on and see if it goes away. You can run sp 2109-3 or 2109-4 in the service mode to adjust the beam in service mode by pressing on the yellow button. pressing the 107 keys and holding down on the clear button.
If this doesn't resolve the issue, you probably need a laser which we have one for sale here.
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
Good luck and please rate me, thanks.
