Apple iPad 32 GB 3G Tablet PC Logo
S
Sue Bird Posted on Oct 24, 2013
Apple id reset password
Can't sign in to apple id, icloud, iTunes Can't reset password Can't get security question (birth date) to work
A
Anonymous
Ouch! My best advice would be to try and call them and see if you can get someone on the phone who could help you to reset your password.
You can give them a call at: 1-800-MY-APPLE
Hope that helps!
1 Related Answer
Jim Thomson
  • 1099 Answers
  • Posted on Dec 08, 2011
SOURCE: How do I reset my iCloud password?
If you go to https://iforgot.apple.com/cgi-bin/WebObjects/DSiForgot.woa/wa/iforgot and enter the information you should be able to get a new password. Hope this helps.
I have forgotten my ipad's apple password
How to reset your password if you have two-factor authentication enabled
  1. Navigate to iforgot.apple.com in any web browser.
  2. Enter your Apple ID email address.
  3. Click Continue.
  4. Enter the phone number that is associated with your Apple ID.
  5. Click Continue. ...
  6. Pick up one of the devices associated with your iCloud account.
More items...
Jun 15, 2018
How to reset a forgotten Apple ID password [iCloud, iTunes, App ...
iMore > how-reset-apple-id
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
How to change birthdate
Use these steps to update or correct the birth date associated with your Apple ID:
  1. Sign in to your Apple ID account page.
  2. In the Account section, click Edit.
  3. Update your birth date. You might need to answer your security questions.
1helpful
2answers
How do I reset my Apple ID?
Follow the following steps:
  1. Tap Settings > iCloud on your iOS device. If you see the option to sign in, you can change your Apple ID now.
  2. Scroll down and tap Sign Out. ...
  3. Choose Keep on My iPhone or Delete from My iPhone.
  4. Enter your password.
  5. Go to Settings > iCloud and enter your New Apple ID and password.
  6. Tap Sign In.
If you need need to reset the password, navigate to the follow link and click 'Reset your password': https://appleid.apple.com
How do I reset my Apple ID and password on my apple iPad Air without boot disc or iCloud password
Follow these steps to reset your forgotten Apple ID password: https://support.apple.com/zh-cn/HT5787
1helpful
How do I sin out of my iPad my iPad won't let me
Understand that all the apps and data on the iPad are associated with an Apple ID so "signing out" of your iPad may render some apps and functions useless.
If you are looking to sell your iPad its best to plug it into a computer and restore factory defaults. This will remove all apps and IDs associated with your iPad.
If you are simply looking for security and worry that while signed into your Apple ID there is a chance for fraudulent downloads and purchases it would be my recommendation to set a password/passcode for the iPad that only you know. This will prevent other users form gaining access to your data without your permission.
The iPad is not meant to sign in and sign out at will but if you need to sign out and add another Apple ID then here are the steps to do so.
There are 2 places in which your Apple ID are linked with your iPad. Your iCloud account (photos/documents/ID) and iTunes (music/movies/apps)
You can adjust settings for these individually under Settings > iCloud and Settings > iTunes & App Store
Simply click on the Apple ID email and then choose "Sign Out"
REMEMEBER, some apps and functions may not work without an associated Apple ID registered with the iPad.
How can I reset my FaceTime birth date info
To set birthdate tap settings,tap FaceTime and make sure set to on.Tap apple Id then view account.Enter apple Id password then enter.Under security info tap manage apple Id.Enter password again then signin.Tap password and security ,then answer both security questions then tap continue.At bottom edit birthdate then tap save.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
