SOURCE: power light blinks red, TV doesn't turn on
if you are not technical i sugest you have this checked out by a professional most probably a fuse has gone from iside or your driver board has gone down. The blinking should be normal after you have turneds it off because some capacitors will be discharging.
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
SOURCE: LG 60PC1D making clicking sounds
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Please rate my reply ++++
