Maytag MSD2756GES Side by Side Refrigerator Logo
Cindy Fry Posted on Oct 24, 2013
Not making ice - Maytag MSD2756GES Side by Side Refrigerator
WRF535SMBMOO Whirlpool refrigerator without door water dispenser, but has ice maker, why does ice maker start and stop making ice ? Ice "arm" is in on position but no ice being made.
If your Whirlpool WRF535SMBMOO refrigerator has an ice maker that starts and stops making ice, there could be a problem with the ice maker itself or with the water supply to the ice maker. Here are a few things you can try to fix the problem:
  1. Make sure that the ice maker is turned on. The ice maker has an on/off switch or button that you may need to activate to start making ice.
  2. Check the water supply line to make sure it is not kinked or clogged. The water supply line delivers water to the ice maker, and if it is blocked, the ice maker will not be able to make ice.
  3. Check the water inlet valve to make sure it is open and functioning properly. The water inlet valve is responsible for controlling the flow of water to the ice maker, and if it is not working properly, the ice maker will not be able to make ice.
  4. Check the ice maker for any visible damage or debris. If the ice maker is damaged or clogged with debris, it may not be functioning properly.
If the problem persists after trying these steps, it is possible that there is a problem with the ice maker itself. In this case, you may need to have the ice maker inspected by a technician to determine the cause of the issue.
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Ice maker makes ice really slow. drops ice every 45minutes or so
i think that is a good time to make some ice.
and depends what temp. you have the freezer setup to.
the colder the ice the longer it takes to make ice.
if you have to or need more information try this
www.ask.com/mfg.name/make/model/
/average-time-to make-ice/
/how-long-should-it-take-to-make-ice-cubes/
2answers
How do I get the ice maker to start making Ice?
WATER + ELECTRICITY = ICE. ABOVE THE ICE TRAY IS A THICK WIRE LEVER MAKE SURE IT IS DOWN.... WHEN THE ICE LEVEL GETS HIGH, ICE PUSHES THIS LEVER UP AND STOPS THE ICE MAKING CYCLE.
Ice will not dispense from kenmore refrigerator
Check to make sure the ice bin has ice in it. If not make sure the automatic ice maker is turned on and making ice.
1helpful
My ice marker will not stop making ice the arm
This problem is going to be the ice maker itself. The arm you are talking about is the shut-off mechanism for the ice machine. Just before the ice machine starts to make ice, the arm slowly rises. Then the arm falls down, if there is ice blocking the arm from falling all the way down it will not make ice because there is plenty! If the arm is able to fall down completely, the ice machine will make ice like normal. If your ice maker is making ice regardless of the arms position, something is wrong with the ice maker. Depending on who replaces this, it could cost anywhere from $100 to $200.
1helpful
2answers
Ice maker not making ice
my ice maker is not making ice what could be the problem, and there is not any water in the ice machine what do i need to look for
1helpful
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
11helpful
4answers
My ice machine stopped making ice after the city shut off the water line for more than 8 hours. How do I make it start making ice again.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
