This can be a motor control fault, and sometimes a fault with the motor itself, test motor windings for equal resistance, and check motor physically for wear / damage. replace motor controller.
SOURCE: elba washer wont drain
There is a a panel 10" by 5" on the front bottom right corner, carefully remove it, and with a torch look inside to see if the belt is still working and still in good condition. With the plug disconnected, remove the belt and try to turn the pump pulley by hand, if there is resistance you may have a jammed or a faulty pump. With machine going, looking through the inspection hole you may be able to see the belt trying to work.
Did you clean the filter, normally it's located at the front bottom of your machine. If you didn't it could fix the problem.
Testimonial: "Thankyou very much for your help, the easiest solution and the cheapest. "
