SOURCE: Europower PMP5000, In the Front Panel there is a
Yes, you can use both the main1 and main2. They are independently driven and please note that they are PSUEDO balanced drives... that is the cold side of the balanced line is NOT driven as a complement, but is merely returned to signal ground by a 120 ohm resistor. This CAN cause hum problems or noise pickup depending on the connected equipment and ground loops. Best to run this into amps/speakers thaat have TRUE balanced inputs and also keep the power source the same for all devices.
