PF means "power failure". This could be caused by an actual power failure, a loose conection, low voltage, or even a bad board. If you have not had a power outage, check the power cord in the recepticle to make sure it's secure. Voltage at the outlet should be 120VAC +/- 10%. If the voltage drops below 108VAC, it can cause you PF display.
Thank you
