Al safe and the only number written on the safe is 2636052. Yesterday coolguy tried but only told me to open the door-----which I can't ???? Please help
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
May I know how old is your safe..?
Safe will not open with your personal code:
Open the safe using the override key and re-program your code.You can only overide or bypass the codes using the Override Key together with your safe.
If you don't have this key, you may need to call Alsafe customer service for this. or you can order the overide key from the manufacturer:
The following information will be needed to process your request:
• Name/address
• Telephone number
• E-mail address if available
• Model # of Safe
• Number of keys requested
• Key number (located on lock tumbler)
• Payment or credit card number
what is the override key? I have no physical key.
Thanks
I have been given this safe and want to change the door code. There is no instruction manual with it.
