SOURCE: Lable in Righthand corner on INPUT1 wont go away
When an HD cable box or satellite receiver is connected with HDMI, the information banner in the corner of the screen does not go away when the TV is on that input. The Plasma Display automatically selects an appropriate screen size when video signals are received from a connected HDMI equipment. The TV's attempt to search for aspect ratio information through the HDMI connection can cause the information banner to stay on the screen, if the data is not found. To turn off the Auto Size, please follow these steps: 1 Press HOME MENU. 2 Select (Option). ( / then ENTER) 3 Select (Auto Size). ( / then ENTER) 4 Select (OFF). ( / then ENTER)
SOURCE: Mits wd 62327 "NOT WORKING"
Sounds like you have been catching it with this set! Sorry about the problems, hope this helps!
You need to check a few things like K9A20 and K9A21 these maybe shorted. Also check R9A02 it maybe open. This will cause the problems you are having. Also for more info www.ctechnicians.com
SOURCE: Mitsubishi WD-52525 red light no picture or sounds, lamp has been replaced.
The hardest part is getting the chassis block out. But if youre mechanically inclined and follow the illustrations and label all the wires you unplug, its not that difficult a job. The soldering isnt very difficult as theyre just capacitors. The chassis is contained inside a metal container and has to be removed as a unit then opened up to get to the PWB PC board.
SOURCE: The screen will not come up but gave this message 'No input signal, go to power save
To isolate the problem, you need a friend with another computer since right now, we don't really know if the video section (or card) of the PC is at fault or the monitor.
You need to swap displays with someone so you can be certain what is actually not working.
The monitor is obviously capable of scanning inputs for a signal and not finding one.
