My LG flatron w2240T turns on,flickers and turns off after few minutes of being plugged to the netbook. The power button blinks then. I tried connecting it to another computer and the problem is still the same. The What could be the solution for this. Your help is much appreciated.
You might need to change the monitor's power supply. I have seen similar problems with other LG models. Usually it is easier to replace the power supply than trying to troubleshoot it.
Replacing the power supply usually involves a few screws and a few cable connections. Troubleshooting the power supply board itself usually involves soldering replacements for blown capacitors.
SOURCE: lg flatron won't turn on
have u checked the internal fuse take the back off and look for a glass fuse
SOURCE: LG Flatron W2234S Monitor Monitor goes black
Ahh the same thing has happened to my monitor! Mine unfortunately is 1 month over warranty. Apparently this is a common problem with this model!
Testimonial: "Excellent advise and many thanks. But it seems that this model does suffer some problems with this fault and LG knows it."
SOURCE: My LG Flatron L1515S Lcd moniter is Flickering
i am having also same problem...
Reddy - 9700704407
SOURCE: Message: OSD LOCKED'' when i press a button on my LG Flatron L1720
change all pressing keys..then press menu key 15 seconds for unlocked.
