Question about Samsung Galaxy Gio s5660
My phone is Samsung Galaxy Mini 2 or S5660D and Whenever i charge it with my original samsung travel adapter that comes with the unit it dont charge , But if i push it hard enough , It charges but after i dont hold it , It looses and dont charge anymore . My warranty just went off last last month . Any solutions that would help me ?
    New Friend:
  • 56 Answers
The charge connection is loose. If it is a Micro USB connector, check inside the jack with a strong light and see if the tiny contact board is bent downward. If it is, then it must be carefully bent up a bit. Use a wooden toothpick and insert the point below the contact board to push it up. Then try using a new Micro USB cable and charger.
Posted on May 18, 2019
Anonymous
SOURCE:
Bajanguru
Sylvester Brathwaite
  • 7752 Answers
SOURCE: Samsung sch-u740
take the phones to a professional mobile store and have them fix it for you
Posted on Sep 20, 2008
Anonymous
  • 9 Answers
SOURCE: how much time to we have to charge Samsung Omnia phone
Depends on your firmware. Updating your firmware on the somsaung site will prolong your battery life. Mine used to last about 2hours with heavy repative use. Music, gps, video etc. Standby would last about a day and a half with a few calls. Now it lasts about 4-5hours with heavy use and standby up to about 4 days with calls here and there.
Posted on Mar 26, 2009
ipodslinger
Steve Brown
  • 688 Answers
SOURCE: My Samsung SGH-t819 Phone turned itself off, won't come back on.
your battery in your phone is worn out.
go to your local cell phone shop and buy a new one..
charge it up and your set
Posted on May 23, 2009
Vignesh V.T
  • 323 Answers
SOURCE: I have bought a Samsung
hi
check the sim card slot of your mobile. may be it get damaged . if so change the sim card slot.
this will fix the problem . and also format the phone .. this will fix the problem..
thank you
Posted on Dec 20, 2010
quintonizaak
Quinton
  • 319 Answers
SOURCE: samsung galaxy gt55570 manual
You can download it from the samsung site
Posted on Jan 19, 2012
What is the most likely reason a Samsung gear 2 neo touchscreen would be unresponsive to turn on and off
If your Samsung Gear 2 Neo refuses to turn on:
1. the first thing I would suspect is a dead battery
2. If it does not showing charging when connected to the charging cradle:
A. it could be either a bad charging cable, wall adapter, cradle, bad battery, or the internal charging connectors.. Do a process of elimination only with OEM Samsung cables and charging adapters.
Note: the Samsung Smartwatch charging cradle is not normally sold in stores, so if you lost it contact Samsung support to get another one [1+(844) 454-5925], or download the Samsung+ app from the Google Play App Store to access Samsung Support contact information
B. If the Smartwatch has been on the shelf for a long time (either in store or not used after a long time) the battery will deplete itself so low that it needs to be trickle charged for 10 hrs or less depending on how dead the battery is.. Rather than being put on it's regular charge adapter for a few. Try inserting the charging cable into a computer USB port instead of into the wall charger adapter (see attached video)
3. If the Smartwatch is on, but won't turn off:
A. it may be a software issue.. Like an app you installed is clashing with another, or maybe an update got corrupted by a bad bandwidth connection.. If this is the case reset the watch and start over.
B. It's possible you have too many things going on and all the RAM memory (the brain) not storage space, has been used up.. Which is a temporary crash, just like when you over load your brain with too much stuff at one time..
Samsung Galaxy Gear not working
Dec 20, 2015 | Samsung Cell Phones
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Audio from KCA-121B (Versatile Link Cable)
It's not the connections it's the phone. Newer phones will allow the phone to charge but will not connect audio through USB connection because they want you to connect through Bluetooth or auxiliary plug.
Sep 08, 2017 | Car Audio & Video
Samsung Galaxy S2 S95G will not charge
Usually this lack of charging is a faulty mini usb connector inside the SII phone or maybe the mini USB plug on the end of charger cable. If you have a friend with a working SII use their phone to verify your battery or try their good battery in your phone. This will confirm it' s a charging / battery issue.
Not sure if you did this:A workaround for a faulty mini USB conn. in the SII would to be to buy a new battery and an external battery charger with battery holder stand. Charge batteries in the stand and change the charged batteries over into the Galaxy SII as needed.
Jan 03, 2014 | Samsung Galaxy Cell Phones
How can I connect my galaxy s3 cell phone to my tv?
How to connect Samsung Galaxy S3 to TV..
There are 3 ways to do this..
1. You can use a compatible MHL adapter that connects to the micro USB charging port of your phone and then a regular HDMI cable from your TV connects to the MHL adapter that's connected to your phone. You will have to connect the Samsung micro USB charging cable to the MHL adapter in order for this to work.
You will be able to see everything that you do on your device, however you will be limited to how you hold your phone if you are trying to play a game and direct what you see on the screen to the TV.
Note: the MHL adapter may overheat your device if you have it on and working for long periods of time.
Youtube example of MHL to TV:
How to Mirror or connect Samsung Galaxy s3 to TV
2. You can use a remote access app on the phone to view on a PC/TV monitor. Depending on the remote access app, there maybe a lag seeing the image on your screen. Most apps like this are paid apps.
3. The Samsung Galaxy S3 phone has a natively installed software tool on the phone or can be downloaded from the Samsung Galaxy App Store (Available after you set up your Samsung account on your phone) that can link to a compatible DLNA device (most TV's that are 2005 or older). The app is called Samsung AllShare Play, or it may also be called Samsung Link
Youtube video:
How To Use Samsung Link previously AllShare Play
Jan 15, 2013 | Samsung Galaxy Cell Phones
How to unlock my phone too many pattern attempts
hi ,
reset your phone and it will be back in its original factory setting...
procedure:
http://www.hard-reset.com/samsung-gt-s5570-galaxy-mini-hard-reset.html
Sep 22, 2012 | Samsung Galaxy GT-S5570
Samsung mini 2 gt-s6500 not charging
samsung mini2 s6500, charging but not charge the battery, its solution please boss
Sep 20, 2012 | Samsung Galaxy Mini 2 Gt-s6500 unlocked...
Samsung Galaxy Gio s5660 Logo
46 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
