I found this diagram online, as I only have access to the full Makita (UK) tech data at work. The spring, pin and dish look like they sit on the rear part of the table/base and go up inside the back part of the guard housing. I can't really tell from this diagram how it is all fixed in place, but you should be able to see how and where it goes together, and hopefully be able to suss it out from there.
SOURCE: How do I assemble the blade guard for my Makita
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
