LG 37LP1D 37 in. LCD Television Logo
J
JULIO Posted on Oct 26, 2013
LOST THE MANUAL FOR MY TV SAMSUNG LNT4032HX/XAA AND I NEED A CODE FOR MY COMCAST CABLE
Samsung plasma tv model HP-T5054 MODEL CODE HP-T5054X/XXA CA5OC9 Manfactured June 2007 Mexico
Plasma is old technology and it is 16 years old and made in Mexico, the worst place for quality control. It is time for a new one, or at least an upgrade. Or you can get a board kit and take a chance on fixing it.
Samsung HPT5054X/XAA Service Manual
ManualsLib https://www.manualslib.com > ... > HPT5054X/XAA
View and Download Samsung HPT5054X/XAA service manual online. Plasma Display TV. HPT5054X/XAA plasma tv pdf manual download. Also for: Hpt4254x/xaa, ...
Boards for it.
https://www.google.com/search?q=Samsung+plasma+tv+model+HP-T5054+board+kit
I need help , hooking up my samsung HT-Z410 HOME THEATER, TO MY LG HDTV, SO THAT WHEN I'M WATCHING REGULAR TV THE SOUND OF THE TV CAN COME OUT TRUE THE HOME THEATER SPEAKERS, CAN IT BE DONE? CAN A COMCAST...
first of all here is a link to the manual....http://downloadcenter.samsung.com/content/UM/200802/20080220095448484_HT-Z410-XAA.pdf and yes it can be conected thru your comcast but you wil need to buy probably cheapest at wallmart an RF Modulator (Less than 20 dollars) and from your cable box (vidieo out, or to tv) install the cable to the rf mod unit (ant in) and that converts it from coaxial cable to rca (meaning a cord with yellow ,red,white push on connectors) plug the red and white into aux input on surround system (see #3 on manual view on backside of surround unit)and and you got it.It your tv does not have a yellow vidieo connection (which is where the the yellow plug into tv)in the back then add a coaxial splitter after the comcast box so that the 1 coax line goes to tv and the other coax goes to the rf mod then thru RCA cables to the surround sound.you may need to buy xtra cables but they are cheap. hope i helped........you may try asking family or friends for the above equipment i described.the newer tv's dont need it and many people have this stuff layen around...good look
I have a Samsund LNT4032HX/XAA i need to find a oem base/stand and cant find one. do you know where i can get one or what the part number is?
the easy way to find one is going to a tv repair or call , and have then macht one for u , the part # is BN96-03697B
Comcastt HD Box indicates "Component 3 - Not supported mode"
Try HDMI if the TV has the inputs or swap the component cable.
Samsung HLP4663wx/xAA 42in DLP
Once you find the codes for the Samsung enter a 1 then the codes listed. So if you code was 2342 enter it 12342
TV shuts off after 10-15 min.
Look through your owners manual for timers, and if the tv continues to shut off..... then there's a problem brewing in your power supply section and associated circuits......
contact me here: [email protected]
443-805-7251
I will help you determine the root cause....
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
