Amana 19.7 cu. ft. / 558 liter Upright Freezer Deepfreeze AFU2004AW Logo
R
Ricky Posted on Oct 26, 2013
How to refill R134 Freon - Amana 19.7 cu. ft. / 558 liter Upright Freezer Deepfreeze AFU2004AW
Rick Lacher
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Oct 27, 2013
Rick Lacher
Contributor
Level 1:
New Friend:
Answers
17
Questions
Helped
1797
Points
39
You have first put in a line tap. If the freezer system has been open it must be put in vac. to get moisture out. Then with interior coil exposed put in a few oz and start compressor. with compressor running add while watching interior coil/ you add slow til coil frosts to 3/4 then your done
If you need further help, I’m available over the phone at https://www.6ya.com/expert/rick_4ed9a6c8e57209e6
ISN'T GETTING COLD NEED TO KNOW HOW TO ADD FREON PLEASE ?
Unless you have a lot of expensive refrigeration tools and a license to recover and buy freon, then you need a serviceman.
Why will it not come on?
The rust shouldn't make any difference.
When you plug it in, does the interior light turn on? If not, suspect the wall outlet - test it for power by plugging in something else. If the interior light turns on, listen very closely to the freezer. It should hum. If it doesn't, toy with the freezer control inside - it may just be turned off. Turn it to about midpoint and listen very closely to it again. If still no hum, wait a short while, then feel carefully on the outside of the cabinet - it may be running through a defrost cycle. The outside of the cabinet may get warm while that's happening, especially around the door gaskets. Wait a while (half an hour, an hour, for the defrost cycle to finish - the freezer should run then.
If it never hums, then the compressor isn't running, so adding freon won't make any difference. Instead, suspect the defrost timer - that's a little electronic circuit board inside.
If it HUMS but never gets COLD, then you potentially have a freon leakage problem. It's difficult at best, though, to refill a refrigerator or freezer - they don't usually have refill taps.
Oh, yes. If the internal light never comes on but you've proven that the wall outlet has power, it's entirely possible that the plug is bad and needs to be redone.
Explain how to refill R134 freon
you should not refill freon, first because it is illegal. second, if you need a recharge it will just leak out again. third, to do it correctly will require braising with an acetylene torch.
2answers
We had a freon leak, I wondering do we need to throw all the food away that was in the freezer??
fixing freon leak at evaporator coils by replacing evaporator on this video. GE side by Side.
Dec 05, 2010 • GE Freezers
1helpful
Hi, i have a whirlpool chest freezer, and the red light has come on and its not freezing up we have cleaned it out and found it started to freez at the bottom then after about 1 hr it turned to...
dear sir/madam
please make sure first your freezer,s compressor is working if it,s working and it,s not making ice it,s mean your freezer copper pipe has been leak from somewhere because you bring it outside for do clean it. it,s very possible during of cleaning it has been leak .then it,s need to brazing and refill freon gas .
please contact to your maintenance personnel for further action
hope answer the question
thank you
please vote!
Sep 07, 2010 • Freezers
The motor seems to be running. Food is not staying completely frozen and I have it turned up to the coldest it will go. Freezer is 5 years old.
Hi, if you have turned the freezer to the coldest and the food is not freezing then you are lacking freon in the compressor.
You need to refill the compressor, besides the freezer is 5 years old.
Take care
Jul 14, 2010 • Freezers
Refrigerator still works fine but freezer while cold is not cold enough to freeze
dear sir,
please make sure first your freerzer,s condesore is clean and fan motor and compressor is running. if its alredy clean and working then try to check amount of refrigarant in your freezer. i think its need to refill freon gas.
thank you
please vote!
2helpful
2answers
Only upper section of the freezer works, heavy ice-buildup.
The symptoms you are describing are typically from a refrigerant (freon) leak. Unfortunately it will be as simple as adding new refrigerant as it will just leak out. The leak will need to be repaired. From my experience with this unit my best guess is that the evaporator coils would need replaced. An average repair cost for this type of repair would be around $400.00.
I hope this helps.
Pulled out wires from compressor on a servis freezer, r134 need awiring diagram to replace wires
Most of the time the compressor reads left to right Start common run. Black is common red is run the other one may vary in color. Rus
Nov 21, 2009 • Freezers
2answers
Small freon leak, food safety
fixing freon leak. Evaporator is leaking freon. Replaced Evaporator on this video
Sep 23, 2009 • GE Freezers
Top Amana Freezers Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you an Amana Freezer Expert? Answer questions, earn points and help others
