Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl...shows op code but the lid is closed and locked and will not unlock.
    New Friend:
My he maytag makes a squeaking noise and it wont fill up. could there be a sock stuck in there or something. and the lock wont lock.
Posted on Oct 28, 2013
6ya staff
SOURCE:
Anonymous
SOURCE: Maytag Neptune TL
The washer lid is open. The lid must be closed to start cycle. Close the lid and press Start/Pause.
Posted on Sep 21, 2007
Anonymous
  • 96 Answers
SOURCE: maytag neptune tl
Code OP means lid is open. If it really isn't, then the problem is with the switch that sense whether the lid is shut or not. Could be bad switch or bad connection.
Posted on Jun 08, 2008
dh1200s
dh1200s
  • 335 Answers
SOURCE: Neptune TL error code op
This forum member’s solution is going in the right direction I’m going to give you a bit more info to troubleshoot the issue if you want to DIY the repair. You have lost signaling from the left lid lock to the control board. The lid magnet could be out of position here is a quick check to try. Raise the lid then press Spin Only key, press on and you should throw the OP alarm to the console. With the lid open place a magnet on the left bumper as shown in this pic. If the OP alarm fails to clear we rule out the lid magnet as out of position.
Next step is to raise the washer top as shown on page 34 of the Service Manual
The Service Manual for reference. Sears Parts Direct for reference.
To raise the top of the machine insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
Disconnect the washer power cord. We can try to reseat the Left Lid Lock a couple of times to see there is there is corrosion causing a issue. Removing the plug is difficult so be careful. See page 34 of the SM, the plug you are going to reseat is shown in the pic on page 34 next to the tech’s thumb in that pic. After reseating a few times power up the machine try a Spin Only cycle, close the lid and hit the on button and see if the left lid lock is signaling the control board that the lid is closed. If you still take the OP alarm then it’s time to remove the left lid lock and inspect for corrosion or a broken wire on the magnetic reed relay. Some owners have found that corrosion has caused the soldered lead ends on the on the magnetic reed relay to break off. They can be soldered back on. See pic’s for corrosion issues and the lead that has broken off the magnetic reed relay.
Follow the SM to remove the left lid lock be careful when you release the tabs on the left lid lock case halves for inspection they break of very easy. Post back if you still need help. If you need to replace the left lid lock here is the part number 25001048 and a link, another. Good luck.
Posted on May 03, 2009
FAV6800AWDIY
FAV6800A FAV9800A
  • 526 Answers
SOURCE: Neptune TL locked lid light stays lit
foxste
I will give you a few things to try that are non technical and let’s see if the Control Board will let you in Service Mode. If so we will try lock and unlock the washer in Service Mode.
Let enter Service Mode;
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Board Output Test
While in Service Mode, pressing the Delicates key will begin the Board Output Test. This test turns on a
specified output after a key press. (Pressing the Delicates key again cancels the test.) All outputs
will be turned off after five (5) minutes.
Now Press the Colors / Jeans key this should lock the Left and Right Lid Locks….. did it?
If the lid locked now press the Extra Rinse Key and this should Unlock the Left and Right Lid Locks….. did it?
Let me know and we will go from there. I’m trying to get a feel for what Control Board functionality you have……Rich
Posted on Apr 30, 2010
caroldon
  • 17130 Answers
SOURCE: How can i bypass my maytag neptune TL aww lid
You will need to open the switch and short the switch using a wire, if what you meant is that there is a switch failure which will not start the program and so the motor will not start on the machine.
Posted on Mar 14, 2012
I have a maytag Neptune TL and OP blink when I try to start it
The OP code indicates that the washer can not determine if the lid of the washer is locked. The locks may be bad or the wiring between the lock and the control board could be faulty. These high efficiency washers will not operate without the lid being locked.
Is the lid locked when you get the OP code? Then I'd check the wiring. If it isn't locking, then you'll need to replace both the locks (one on each side) and the magnets. If you forced the locks apart to open the washer, then you'll probably need to replace these parts.
Please add a comment with the model number of your washer, if you'd like more information about the replacement parts or diagnostic tests that may be appropriate.
I hope this helps.
Sep 21, 2016 | Maytag Washing Machines
I have an OP message on my Maytag washer FAV6800A/FAV9800A . The washer is not locked I can open the lead ...when I close the lid and start the washer the OP error comes up. Any help will be...
If you get no help at this forum Google This ""Neptune TL Washer FAV6800AWW""
5th post down you will find the SM and support for the "OP" error code. You have lost signaling thru the Left Hand Lid Lock............DH1200s
Aug 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Code reads "OP" what does this mean?
Go here Neptune TL Washer FAV6800AWW
read the 7th post down ""issues related to the Left Hand Lid Lock for FAV6800A or FAV9800A machines.""
Mar 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl error op
You have lost signaling thru the Left Hand Lid lock or you could have a Lid Magnet out of posistion;
Google Neptune TL Washer FAV6800AWW
6 or so post down and I have service notes to help you troubleshoot.
Mar 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL washing machine, it runs almost all the way through they cycle but on the last spin cycle it stops and the digital display shows LO. Can you help me?
LO error code:
Locked: Lid has failed to unlock -
the machine has repeatedly tried to
unlock the lid. Push lid closed to
make sure nothing from the inside is
pressing against the lid, preventing
unlocking.
Is that the issue? Have the Lid locks failed to release and you can't open the Lid?
Or have the Lid Locks released so you can open the washer lid but the error code LO remains?
If you want to DIY I will help you.
Google this Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum no cost and you can get the Service Manual from this site.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine.
In that Sticky are other what I find to be common Service Repair notes for issues with the machine.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help. No cost to you for the support..........D*ick
Mar 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
It says lid is open but its not
You have lost signaling thru the lefthand lid lock
Google this "Sticky: Neptune TL Washer FAV6800AWW"
Go to the 5 post in the sticky for the Service Manual and within the Sticky I describe the issue of OP, OD, and FL error codes.
Ypu don't mention in your description but I assume your machine is throwing an OP or DO error code.
I describe how to diagnosis and repair the issue.
Jan 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have maytag neptune tl,i moving3 week ago i do a coneccion and a have a cod en tha machine OP,and dont do nothing.
Sorry should read ""Confirm the model number and the 1st two digits if the serial number and I will see if I can help. Is the machine a FAV6800A or FAV9800A? Any error unbalance codes during the spin cycle like dc or UC? ""
You have lost signaling thru the left hand lid lock or have a lid magnet out of posistion.
With the lid open try placing a magnet over the left hand grey lid bumper with the lid open.
If the OP error code clears then it's a Lid Magnet issue. If the OP error code dosen't clear we need to troubleshoot the Left Hand lid lock or replace. I prefer to troubleshoot further before buying a part. Let me know what you want to do. If you want to troubleshoot/DIY the repair we need to move your issue to a better DIY appliance repair forum. Try the external magnet first and rule out a Lid Magnet out of position issue.
See pics;
See if an external magnet over the left grey lid bumper will clear the OP error code.
Nov 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
MY MAYTAG NEPTUNE MODEL FAV6800AWQ KEEPS DISPLAYING THE LETTERS OP
You have lost signaling thru the Left Hand lid Lock. The washer has not see the lid go closed thru the signaling with the magnetic reed relay in the Left Hand Lid Lock.
You could have a Lid Magnet out of position or severe corrosion. You can place a large magnet over the Left bumper like this and see if the OP error code clears;
See this post for troubleshooting the OP error code Left Hand Lid Lock Troubleshooting I go over OD error code troubleshooting but you troubleshoot the issue the same way for the OP error code.
If the Lid Magnet is not out of position you may have an open circuit thru the Magnetic Reed Relay as shown in the Pics of this link Left Hand Lid Lock Troubleshooting.
The p/n for the Left Hand Lid Lock is 25001048
Some other handy links. The Service Manual for reference. Sears Parts Direct for reference..........Rich
Jun 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl
Jun 06, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL
Aug 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
411 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
