Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
