You'll need to do a factory reset:
1.
With the device off, press and hold Volume
Up and Power.
2.
Release the Power button when you see the logo, but continue
to hold Volume Up until the recovery screen appears.
3. Use
the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4.
Press Volume Up continue.
This will reset you device to factory settings, however
anything on your SD card will still remain.
At this point you will need to start fresh as if you just
bought the device -- register with your email address, etc.
try this link:
http://www.fixya.com/support/r5393255-windows_password_recovery
If you have lost
windows password, the best thing for you is creating a password
reset disk.Actually,when you add a password to your pc,the
first thing you should do is creating a disk in case you lost the
password.But how to make a password reset disk after you have lost
the password ? Follow these
You need to prepare:
1:A blank
CD/DVD or USB flash drive
2.A computer which can link to
internet
3.A program called Windows
Password Key
Then let's begin
Step 1.Login to a PC which
can link to internet,Download and install the program from in that
PC
Step 2.Run the program and burn to CD/DVD OR USB flash
drive
Step 3.Turn to your locked PC,insert the newly create CD or
USB to your drive.Reboot the Computer
and then follow the instructions,it is very easy to use.
Lost user password in XP with
networking set-up on HP
The best way to do this is using the Offline NT Password &
Registry editor.
You can download it at the following link:
http://pogostick.net/~pnh/ntpasswd/
This
utility will enable you to reset the password of any user that has a
valid (local) account on your Windows NT/2k/XP/Vista etc. system.
The
link above includes some directions on how to use this utility.
