Cooling System for Suzuki Swift Logo
A
ABDUL WAHID Posted on Oct 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
COOLING SYSTEM - Cooling System for Suzuki Swift
JohnjacobJinglehimmersch
Level 2:
Champion:
  • Expert 234 Answers
  • Posted on Oct 31, 2013
Expert
Level 2:
Champion:
Answers
234
Questions
0
Helped
47714
Points
466
Yea, I have nothing for this, you have to describe the problem at least.
2answers
How To Fix Toshiba Cooling System Error?
Amazing Tips and Tricks to Fix Toshiba Cooling System Error
  1. Method 1: Set the Cooling Policy of the System to 'Active'
  2. Method 2: Using Toshiba Health Monitor.
  3. Method 3: Removing Everything and Reinstall Windows.
  4. Method 4: Replace the Hardware of the System.
  5. Install a Temperature Controller Software:
  6. Use the Cooling Tray:
https://errorcode0x.com/resolve-toshiba-cooling-system-error/
1helpful
What Should I do to Maintain the cooling system of my Hyundai Verna 2016?
In the cars, the engines use liquid cooling which comprises of various components and thus the system is a bit complicated. Here are a couple of tips you should follow to keep the Hyundai Verna engine cooling system running fine so that it doesn't surprise you in the middle of nowhere, check out the mention link
=> Top 4 Tips to Maintain Your Car Cooling System
=> How to Maintain Car Cooling System
1helpful
Wiring for cooling system ford escort zetec 1996 1.6i
Wiring for cooling system ? You mean cooling fans ? 1.6 ? This vehicle has 1.8 L or 1.9 L . This cooling system has two electric cooling fans . Three relays , cooling fan power relay , cooling fan hi speed relay an the low speed cooling fan relay. The powertrain control module controls these relays. Go here http://bbbind.com/free_tsb.html free wiring diagrams .
2answers
HOW TO LET THE AIR OUT THE COOLING SYSTEM ON A 2002 JEEP GRAND CHEROKEE
You should have a vacuum puller, but alternatively, you can purge it by letting in freon on the low side and opening the high side for about 4 seconds, that should purge all the air in the system.
1helpful
Oil in coolant
Thoroughly flush out the coolant expansion tank and cooling system, radiator , engine block ect... with a commercially available cooling system flush (Prestone or any other brand). Oil will damage the rubber cooling system hoses. Refill the cooling system with the correct amount of fresh antifreeze and drive the car after the cooling fans have cycled on and off. When the cooling system has cooled down top up as required and keep an eye on the cooling system for a few weeks to see if the problem reoccurs or if someone had inadvertently put oil in the reservoir.If not I'm more leaning toward a blown head gasket. it will run fine but you will have to keep the water clean out. to fix it buy a head gasket and surface the head..you have a blown head gasket
How to change a radiator
1988–91 Models
  1. Disconnect the negative battery cable.
  2. Properly drain the cooling system into a suitable container.
  3. Disconnect the fan motor and motor connector.
  4. Disconnect the upper and lower radiator hoses.
  5. Disconnect and plug the automatic transaxle cooling lines at the radiator, if equipped.
  6. Disconnect the coolant reservoir overflow hose.
  7. Remove the radiator attaching bolts and brackets.
  8. Remove the radiator with the cooling fan attached.
  9. Remove the cooling fan and shroud from the radiator. NOTE: Check all cooling system hoses for any signs of damage, leaks or deterioration and replace if necessary. To install:
  10. Attach the cooling fan and shroud to the radiator and install the assembly.
  11. Attach the radiator bolts and brackets. Tighten the radiator bracket bolts to 7 ft. lbs. (10 Nm).
  12. Connect the coolant reservoir overflow hose.
  13. Connect the automatic transaxle cooling lines to the radiator, if equipped.
  14. Connect the upper and lower radiator hoses.
  15. Connect the fan motor and thermo-switch wire connector.
  16. Refill the system with the proper type and quantity of coolant, check for leaks and bleed the cooling system.
  17. Reconnect the negative battery cable. Fig. 7: Cooling system components — 1988–91 engines 86833085.gif
1992–95 Models
  17. Reconnect the negative battery cable. Fig. 8: Cooling system components — 1992–95 engines 86833086.gif
1helpful
How 2 fix a broken cooling system connector on a 1998 chevy tahoe
how can i replace the cooling system connector to my tahoe 1999?
I already purchased a new cooling system connector.
Should I pull out the hose from the old cooling system connector unscrew the old one, screw the new cooling system connector and insert the new one?
How do you remove the water pump on a 2006 monte carlo
  1. Drain the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  5. Remove the water pump bolts.
  6. Remove the water pump and gasket.
  7. Clean the water pump mating surfaces
    1. Position a NEW water pump gasket and the water pump to the engine front cover. Notice: Refer to Fastener Notice.
    2. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolts.
  2. Install the drive belt.
  3. Tighten the water pump pulley bolts. Tighten the bolts to 25 Nm (18 ft. lbs.) .
  4. Fill the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  5. Inspect for leaks.
Hope this helps
Top Suzuki Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Suzuki Vehicle Part and Accessory Expert? Answer questions, earn points and help others
