SOURCE: need tv code list for urc-4605
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4605
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
SOURCE: tv codes +one for all remote control +URC-4220
Hi, the codes I have for JVC TV's are as follows: -
027, 051, 068 & 081
Try them & see how you get on.
Cheers
Shaun
SOURCE: urc-3021Boo one for all set up and codes for a sanyo tv
To control a Sanyo TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the code 0154.
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, try the auto-search function.
To search for a code for your TV:
Hope that helps.
SOURCE: REMOTE CONTROL CODE FOR HAIER TV
We have a Haier TV model 3 HL32R2a, the cable remote no longer turns the set off or on or controls the volume. We can only do that with the tv remote. Tried putting in the universal code, and the Haier code and it didn't work. Please help.
