Correct, OE is a drain error and is displayed when the
washer is unable to drain water. Please check the drain hose and drain pump
filter located inside the bottom front panel for any clogs to clean the error. Please get back to me if you have any
other questions.
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Hi, The most common cause of an OE error code on a modern LG dishwasher is: 1. Blocked drain hose 2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction) 3. Failing drain motor. else you need to REPLACE THE PCB POWER CONTROL BOARD Good Luck!!!
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
