Coby 4GB Kyros MID8048 8" Tablet Black Logo
Ed Walker Posted on Oct 29, 2013
Bought returned unit need to reset it to factory setting as new
How do I restore my Samsung tablet to the origional form?
Hi Erica, the only way to restore your tablet to original form will be to factory restore/reset.
This is how to do it.
1: Click on your Settings Icon.
2: Click on Back up and reset
and Automatic Restore so they are clicked, then click on Factory data reset.
3: Click on Reset Device
4: Then click on Delete all
Your tablet should now restart and look like the day you bought it.
Please note that the factory reset might take a few minutes to do the reboot. Don't turn of or disturb the the rebooting, wait until it finish by itself.
25387709-53uihbay4bejfnwqkcsmqi02-5-10.jpg 25387709-53uihbay4bejfnwqkcsmqi02-5-3.jpg
25387709-53uihbay4bejfnwqkcsmqi02-5-15.jpg 25387709-53uihbay4bejfnwqkcsmqi02-5-6.jpg
Hope this helps.
2answers
I need to do a hard reset on new ipad 4
When you get into "settings" you have to scroll down to the last option which will be "reset"
1helpful
2answers
My nabi dreamtab wont reset why?
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabiâ„¢ Sync.
How to reset a pandigital 7270FW Tablet
Maybe this video might help
https://www.youtube.com/watch?v=2yvBRURe-3I
or this
http://www.fixya.com/support/t10680045-reset_pandigital_planet_tablet
There should be a small hole to stick a paper clip into to do a reset,press it gently til it reboots
Alos can do it following this advice
There are two ways to do it. You can either update the firmware and it will erase everything for you, or you can do a factory reset, and return to factory settings. Go to Settings, PDN settings (not the Android settings menu) and scroll right to the Reset Defaults location. Tap on the reset button and you will be taken back to factory default settings. It might take a while to reload, but after everything it will be back to factory defaults from when you first bought it. Updating the firmware might be your best option if you care to resell it, because it may cause less issues for the next person and less chance of any returns.
Reset
Factory Reset: go to Settings from the home screen. Click on "Privacy" and then click on "Factory Data Reset." Go through the data reset process. This will remove all personal data from the device.
Or
Shutdown the tab, enter the recovery console by holding both the return button and the power button until you see the android icon with a triangle. Press return button again and recovery menu will appear. Navigate through the recovery menu using vol up/vol dn or home and menu buttons on the tablet. Select "wipe data/factory reset." and then "reboot system now"
11helpful
3answers
How to reset Pandigital 7 in. Planet Tablet to factory settings?
3helpful
My apps libaray on my coby kyros mid7015 isnt working!!! everytime i try to go into the apps libaray it keeps saying that theres been an unexpected problem and that it has to "force close" why is...
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
