SOURCE: Need 3-digit code for tv remote
I'm looing for the TV brand to choose so I can find the right 4-digit code for an Element TV (Element is not listed)
SOURCE: remote control codes for freeview and dvd recorder
the codes that came with my one for all 6 dont match the bush free view box, any 1 know any more or where i can get them please.
SOURCE: universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you
have one the "magic" button for three seconds, a light should then
flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: Universal Remote code for VCR/DVD recorder.
Use the remote's "Code search" feature. It'll run through every code in it's database and when you see the player turn off, you store the code. If non of the codes work, then it's not compatible.
Hope that fixed ya...
Geno
SOURCE: RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
there is no "code search" button on the RCR3273???? can anybody help?
