On page 141 the manual says
[PLEASE CHECK THAT THE LENS IS ATTACHED CORRECTLY]
• Check that the lens is attached correctly and then turn the camera off and on.
> If the message persists, contact the dealer or your nearest Service Center.
on page 14 the manual says :
This unit can use the dedicated lenses compatible with the Micro Four Thirds System lens
mount specification (Micro Four Thirds mount) such as the lens included in DMC-G1K.
Select a lens that matches the scene being recorded and your use of the pictures.
If you use a lens other than a dedicated interchangeable lens, auto focus cannot be
activated and accurate metering is not possible. Also, some functions will not work.
You should put the camera in mode manual, to avoid the error you get.
to see what lens you can use see what the manual says:
Refer to catalogs/Web pages for most current information regarding compatible lenses.
http://panasonic.co.jp/pavc/global/cs (This Site is English only.)
SOURCE: Canon, wont focus, dark viewfinder
try cleaning the contacts on the bottom of the lens, where it mounts to the camera body. This is a simple step to take and one that I try to remember to do frequently when I am switching back and forth between lenses frequently. get a magnifing glass and look closely at the contacts on both the lens and body. I have 5 canon bodies and the 75-300 IS lens is one of my favorites. It is ALWAYS mounted on either an XTI or XSI and within arms reach at all times. I have a hook and hang it from the headrest of the passenger seat when driving so that it is always ready at a moments notice. I have never had a problem with that lens.
SOURCE: Error message states "lens cap attached" when that
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
