Did you pull the power plug when you disconnected all the connections?
Yes I pulled all the connections out as well as the mains lead from the wall. TV recognises the inputs but no signal on any.
Turn it off and unplug the power from the wall. Wait 10 minutes. Plug it back in. Wait 2 minutes before turning on..
That is supposedly the process to reset the main board. Hopefully the main board doesn't need replacing. (Sorry for the separate posts, I can't figure out how to edit the comments.)
Have tried it and still no luck. TV did make a quiet "swoosh" sound up and down and then showed no signal again. Thanks for the suggestion but will need to call someone out to sort
The other thing to check is if there is a signal getting to the TV. Are any of the cable or antenna connections loose etc? Are you using a cable or other box/modem that might need resetting? Do you have a computer you can pug in to see if the TV works as a monitor?
