Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
D
David Parks Posted on Oct 29, 2013
Evaporator fan Went to clean around the coils and fan is not on. Compressor is on. Fridge and freezer are cooling. Is it just not working or is it suppose to be on too when fridge kicks on?
gmonett
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Jan 16, 2014
gmonett
Contributor
Level 1:
New Friend:
Answers
18
Questions
Helped
3970
Points
18
Usually the fan is automatically turned on when needed. Good job on cleaning the coils; number one issue with refrigerators.
5 Related Answers
A
Anonymous
  • Posted on Feb 23, 2008
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
A
Anonymous
  • Posted on Jul 23, 2008
SOURCE: Freezer is staying cold (below 0), but Fridge won't cool
Failure to stay cold
Anonymous
  • 4 Answers
  • Posted on Aug 15, 2008
SOURCE: Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech.
docjohn174
john gagnon
  • 943 Answers
  • Posted on Oct 30, 2008
SOURCE: fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
.thanks for your question i would try a hard, to start re lay on it after its cooled down. it might just do the trick. the appliance doc
Anonymous
  • 1122 Answers
  • Posted on Nov 04, 2008
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Compressor start no longer working then stop cooling?
    There are several possible causes when a refrigerator doesn't keep your milk cold or your ice cream frozen. Before you attempt more complex repairs, try these simple fixes if your refrigerator is not cooling and if your freezer is not working:
    ·Be sure the fridge is plugged in and getting power. The light should come on when you open the door.
    ·Check the thermostat to make sure it hasn't been turned way down by mistake. If your fridge/freezer thermostat isn't working.
    ·Be sure the vents on the back of the freezer compartment aren't blocked by boxes of ice cream or frozen vegetables-the vents have to be clear for cold air to circulate.
    ·Vacuum the coils under or behind the fridge. Clogged coils can cause poor cooling.
    ·Check to make sure nothing is stuck in the condenser fan and that it spins freely (models with coils on the back won't have a fan). To do this, unplug the fridge and pull it out. Clean the fan blades and spin the fan by hand to see if it's stuck. Plugin the fridge and make sure the fan runs when the compressor is running. If the fan doesn't run, see the directions below, which show how to replace it.
      Replace the Refrigerator Evaporator Fan
      ·Here are some refrigerator troubleshooting tips to help you zero in on the problem if you notice your fridge not cooling. If you can hear the compressor running but the fridge isn't cooling, the problem is most likely either frost-clogged evaporator coils or a stuck or broken evaporator fan. Evaporator fans often squeal or chirp when they start to go bad. You'll know it's the evaporator fan if the noise gets louder when you open the freezer door. The evaporator coils and fan are located behind a cover in the freezer compartment
      ·If you remove the cover inside the freezer and find the coils completely filled with frost, take everything out of the freezer and fridge, unplug it and let it thaw for 24 to 48 hours. Keep a few towels handy to soak up water that may leak onto the floor. When all the frost is melted away, plug the fridge back in. If it works, the problem may be a defrost timer, defrost heater or defrost thermostat. Replacing these parts isn't difficult, but figuring out which is faulty requires troubleshooting that we won't cover here. Call a pro if you suspect a problem with these parts.
      ·Normally the refrigerator condenser fan and compressor, located near the floor on the back of most refrigerators, come on when the thermostat calls for more cooling. If you don't hear the compressor running after the door has been left open for a while, it could mean the condenser fan is stuck or worn out or that the relay or compressor is bad.
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Kenmore refrigerator will not cool. Freezer works
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
2helpful
Cooling system of my LG frostfree refrigerator is not working for the last two days .No one is attending the complaint from service center , Panvel Navi mumbai . Need immediate help/
2helpful
Whirlpool Side By SIde Refrigerator Freezer stopped cooling
2helpful
Lights on Freezer and Fridge not working
1helpful
Dometic RM763. Freezer=Yes,Fridge=No
2helpful
Ice maker not working and Freezer not keeping things frozen.
2helpful
2answers
Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
