Can you tell me basics to get started. how to get old bulb off. basics to installing new bulb.
Pull the bulb and retaing ring any way you can. don't try ti save them. you get a new retaing ring with the bulb. put the new bulb in then work the retaing ring in with a screw driver,clean everything behind the bulb before you put the new on in.
You need a pick with a hook on the end-around the outside of the bulb is a ring that has to be removed--clean area and instal "new" bulb and retaining ring
Use a flat screwdriver and pry the old bulb off. Take that with you to the parts store and get one to replace it. Clean the area where the new primer bulb will be. Simply press new primer bulb and retainer ring back in.
lawn mower will only start when priming carb.will only run for 30 seconds.and where is govner
