SOURCE: rattling noise during spin cycle
Most noises
from a washing machine occur during the spin cycle. If you hear loud
thumping during the spin, the load of clothes may have become
unbalanced. Stop the washer and redistribute the clothes, then re-start
it. Repeat these steps if necessary.
SOURCE: washer makes alot of noise
If the sound your hearing is a " roar " , then its the spin bearings bad and the smell could be the motor , working harder due to the bearing . Eventually , this bearing will wear enough , you'll start seeing water on the floor , gradually more and more . I would suggest you start looking for another washer , due to the cost of replacing the bearings and seal kit .
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
SOURCE: My Maytag Bravos washer stopped on the spin cycle
You might have items between tubs. Are you using HE soap in the correct amount?
Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
