I removed SweetPacks from Change/Remove list on System Control, but it's still there. Help!
Revo uninstaller is the only way to remove problem programs. Be sure you do as instructed by revo to completely remove program. There will be no traces left if done right. http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html . Now that you have gone that far you will have to search for any left over files. Type Sweetpacks into search. Then right click on result. Then click properties. It will then give you a folder location.Find it. Then delete folder. Personally I always use Revo uninstaller for if done right, it never leaves anything behind.
SOURCE: Programs missing from add/remove list
Once you have the "Add or Remove Programs" window open look at the left side and make sure you have "Change or Remove Programs" selected. Also make sure you have the checkbox ticked that says "Show Updates".
As for the other programs in the list without the chage / remove option. You need to first click on the progam in the list to show that option.
