try to set it back to factory.
press and hold the "Volume Up", "Home", and "Power" buttons.
Release the buttons when you see the recovery screen and the Samsung logo.
Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...
On the next screen, press "Volume Up" to continue.
Once the tablet has shut down, press and hold the Volume Up and Power buttons simultaneously until the Samsung logo appears. The Samsung Galaxy Tab will boot into ASR (Android System Recovery) mode. 3. Use the Volume rocker to highlight the 'wipe cache partition' option and the Power button to select it.15 Sep 2015
Plug into charger hold power button down until device powers down
charge fully then disconnect and power up
might work or look at this site to erase cache entirely
https://appauls.com/how-to-fix-the-samsung-galexy-tab-reboot-loop/
How do I get my Android tablet out of safe mode? Use the ... Restart your device by holding the power button, then tap Power off. ... Did this answer help you?
Mar 15, 2014 - Use the Safe Mode feature on the Samsung Galaxy Tab 3 to start the Android OS with the system default software. ... When the Galaxy Tab 3 logo appears on the screen, press and hold the "Volume Up" button. ... Once the device has completely powered off, you can press the "Power ...
• First switch off your device.
• And then wait for some time and then get it restarted by pressing the `Power+Volume Up+Down` buttons all at once.
• Now you will be taken to the option of `Recovery Mode` tab.
• In that mode select the option of `Wipe/Factory reset data` tab using the volume keys to scroll and use power to select
• Once you select power it will reboot your tablet
• It will switch off and switch on back again this time it won't freeze on your start up screen
try to hard reset it:
1. turn it off
2. press volume up + power button
3. when logo appeared leave the power button but not the volume button
4. choose from recovery menu wipe data/factory reset then select yes then choose wipe cache partition using volume buttons to navigate and power button to select.
You can hold the home button and the power button simultaneously until the iPad powers off and resets itself. Once the Apple logo appears, release the buttons. Hope that helps!
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo ( about 3
seconds), but continue to hold Volume Up until the recovery screen
appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Power to continue.
The Galaxy Tab should then go through the hard reset process ( formatting user data).
4. When formatting completed, navigate to select Reboot system and press Power.
