SOURCE: water sighpons back into washing machine
Possible your filter is clogged, clean out. Your exit hose should not go too deep into the standpipe in wall, and it should not be air tight there. The height of approx 3 feet should be maintained. You can check the exit hose by laying it to floor level to see water flow out freely, or put into sink & try 'spin'.
If things work out, rate.
SOURCE: Tub leak on a Kenmore Washing Machine Model
you could probalby get away with a marine epoxy to repair thecrack (depending on size) , althouth replacing the tub would be the best "feel safe" --- "no longer worry about possible floods". buthte cost and time to switch the puter tub is problably cheaperto buy new machine
SOURCE: Dont want to save suds.( Kenmore model 5450290 Suds saver washer)
disconnect the wireing to the suds saver valve and tape the ends off.
valve will no longer open for the suds cycle
SOURCE: I have a Kenmore washer with suds saver. I do not
Can you provide the exact Make, Model and Kenmore model number?
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.
See the Sears Parts site and / or their Answer Site for manuals.
Answer:
http://www.managemyhome.com/
Parts description and possibly manuals:
http://www.searspartsdirect.com/partsdirect/index.action
SOURCE: have a whirlpool model LSS7233dq0 suds saver , the
the diverter valve for the suds saver is faulty. Go to this valve and operate it manually to see if it is not jammed. THEN TRY IT ELECTRICALLY TO SEE IF THE SOLENOID PULLS IN THE VALVE. cHECK THAT YOU HAV e the cycle switches operated correctly too. Next see if there is power at the valve at the correct time cheers T
The Sd code on most Kenmore Elite HE washers indicates a suds lock (usually caused by excessive suds do to overuse of detergent). Check for the presence of excessive suds in the washer. If you see a lot of foam, the code is likely caused by this problem. You will likely be able to drain the washer and spin out the clothes once the suds dissipate. Run an empty cycle with 1 cup of liquid chlorine bleach through the washer to help rinse out suds residue. If you see foam emerging during the empty cycle, you may need to repeat this process. You can also use Washer Magic or AFFRESH to help clean suds residue out of the washer. These products are available at your local Sears store or the grocery store. Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity. You may need as little as a tablespoon of detergent in a high efficiency washer due to the low water level. You may need even less for a while since the clothes will likely have detergent still dissolved in the fibers that will emerge during subsequent wash cycles.
There are many different models of Kenmore Elite HE washers. If you do not see any apparent problem with excessive suds or need more help, resubmit your question with additional details and the full model number of your Kenmore Elite HE washer.
