Some F-35 notes:
F35: ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
Item 20$86:Keep in mind if too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
