My TV just did this 2 days before Thanksgiving. I just messed with it and fixed it today. Unplug it from the power source for atleast one hour. Plug it back it. Hold the power button til constantly flashes red and green. Wait at least one minute while it continues to flash. Turn it off. Flip the big power source button on the back to off && then on. Then hit the power button on the side, and it should turn on. Worked for mine. Hope it helps.
When your TV (EHT) High voltage is not proper run or Power supply is not strongly create voltage.
Solve: If you repair it self,You check thoroughly.Some of components may be damage in power supply.
Check diode,capacitor or high voltage power transistor,any kinds of fuse.
You most likely either have a faulty power supply or high voltage transformer that is failing. You can test them both with a voltmeter or multi-tester. The capacitors on the newer sets seem to overheat and burn out quickly
It is symptom of weak Lamp in your TV, replace Lamp with following part number.. A1606034B
LAMP BLOCK XL-2100U It is available in Sony Accessories for $200 Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Their is no more you can do. You need a professional. Stop using the TV until it is repaired. Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc Milwaukee Wisconsin 53405 (414) 762-8600 Established 1974
I bought a 37'' Sabre when I got back to the states in 07. Now, the power button is flashing red/yellow/green and won't turn on. Anyone with these tv's having this problem?
