I recently purchased a WD 500 GB eSATA HD to replace my Samsung 120 GB HD on my Dell XPS M1210. I used Norton Ghost to image my original disk and restore to the new 500 GB disk. After the restore, the new 500 GB disk only shows 120 GB available and will not resize to its original size. Tried reformatting, repartitioning etc. I appreciate any and all help/support in this regards. Thanks, Fadeaway
What you are backing up with Ghost is a mirror image of your original hard drive. You may have repartitioned the new drive for 500 gig but you’re restoring your original partition size of 120 with Ghost. That’s why they call it call it “Ghost”, it’s a ghost image of your drive. If you want to use the full capacity of the 500 gig drive you have 2 options:
1) Re-install you operating system software from scratch and install docs, pics, etc..
2) Create a second partition (500 gig minus 120 gig) and assign it a logical drive letter.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Walterb_8 & Geekman..Appreciate your feedback to my issue. After spending will over 40 hours, I finally discovered the real cause to my issue. I actually tried both of your suggestions in the hope of fixing the issue including formatting, repartitioning, resetting the MBR and manually editing the Partition Table. Unfortunately all these lead me back to the same results, the HD was pegged at 120 GB while physically it was meant to be 500 GB.
I then stumbled onto a thread in another forum that lead me to a wealth of information on Dell MD and the inherent HPA partition. It seems Dell has some custom code in its MBR which seems to have been copied in the cloning process. This code is triggered under certain circumstances such as when you press the MD button. Once it is pressed, the MBR triggers a series of events within the boot sectors which cause the 500 GB to be reconfigured as 120 GB where the expected HPA partition is available. The remained of the HD is then hidden and cannot be seen unless you use a specific tool.
I am attaching the page links associated with aiding me in addressing my issues and resolving it. I also want to thank all those that have contributed to the wealth of information on the subject especially the pages linked to Dan Goodell.
http://www.goodells.net/dellrestore/medi...
and
http://www.goodells.net/dellrestore/hpa-...
and
http://www.wilderssecurity.com/showthrea...
