I have a Sony KV-27ts27 television that I bought secondhand, without a remote. I need to know how to turn on closed captions. When I had cable service with AT&T Uverse, the closed captions were working but I moved to an area where Uverse is not available. The new cable provider (Charter Communications) says that although closed captions are turned on for analog and digital tv on the box they provided, the closed captions will not display unless they are turned on on the tv, and without the tv remote it can't be done. I reprogrammed the new cable remote with every code listed for Sony tvs, but none of them allowed me to access the tv menu. I was able to access the tv menu with my old Uverse remote, but could not understand exactly how to turn on the closed captions. If anyone can help, I will be so grateful, I have a deaf family member who can't enjoy tv without the closed captions. Thank you!
    Sergeant:
  • 232 Answers
Here is a link to the manual. It appears to me your set does not support closed captioning. It is too old. It mentions channel captioning, but that is for a channel identifier for reference. http://diplo-best.com/314.php?k=ac30c98e172782467c3895e8cba613ad&ID=87078&q=SONY KV-27TS27
Posted on Oct 31, 2013
6ya staff
SOURCE:
Anonymous
SOURCE: turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Posted on Aug 23, 2008
Anonymous
SOURCE: Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there.  Worked for us - got the idea from another fixya post.
Posted on Aug 28, 2008
Anonymous
SOURCE: Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Posted on Mar 17, 2009
Anonymous
SOURCE: Need remote control code for ATT U-verse
well i have a vizio 32' lcd hdtv and the code 1343 worked for me!! the 922 didnt.....1343
Posted on Nov 09, 2009
stormlover
stormlover
  • 4 Answers
SOURCE: Remote Contol Codes for Lloyds brand Television
lloyd's lcd1932wb - i need info for setting up my universal remote. i dont know which category (tv, cable, vcr or aux) do choose for setting this flat screen and i cant seem to find the code doing a manual search? does anybody know if theres a 4-digit code to program my universal remote? i hav try'd manually searching but i just cant figure this one out?... its frusterating... could someone please help me? thanx
Posted on Nov 29, 2009
Turn off closed caption on Sony TV Model KV-32VA2
I need correct model number of your Sony tv as KV-32VA2 is invalid model number.
Please recheck model number that would be written on sticker pasted at back of tv to provide you helpful info about how to turn off close caption.
Thanks.
Sep 18, 2010 | Televison & Video
Hi - my mom's sony tv - kv-27s42 ---- even after reading the manual I can not stop the closed captions from appearing - can you please help? Thanks! Tony
First, it is a older set.
Second: if the CC is coming from the set you will need the original Sony remote---Look under captions and either turn them off or to something other than CC1.
Third:If some kind of cable or other box is being used to supply signal to the set the CC can be coming from it! Yes, these boxes also have CC settings.
Look at settings in set first and in the box (if you are using one) second.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Sony KV-27S42 27" TV
Random close captioning shows up only disappears after turning tv off
Hi you can removed this by using your remote and access to your menu/close caption seting option and turn it off /or by using the menu button on the tv set
hope that help you.
Mar 21, 2010 | Sony KV-32S42 32" TV
Closed caption stays on even though the set up menu states the "caption vision" is off
if you are on a cable or dish box caption is coming from the box, on cable turn TV on, box off press menu, get box service menu, turn caption off pretty simple
Aug 09, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My kv-20520 tv wont turn off closed captoining
Maybe you have to scroll through the Closed Captioning options or your menu for a bit until you find it and maybe you blew your speakers
Jul 23, 2009 | Sony KV-20V80 20" TV
Closed captioning used to work. Disconnected TV to do some remodeling, now it doesn't show caption info. Tried selecting different menu options, i.e. CC1, CC2, etc. No luck. My TV is a Sony Wega...
You need to use a remote control to fix this one. There are options, and some say different things. but there is always a seperate button for Closed Captioning on TV's.
-hannah
Jul 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Closed caption is on and I want to turn it off.
Press "Display" button on "TV remote" to turn it OFF.
Feb 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
