Airlink AWLH3026T 802.11g/b Wireless Adapter Logo
Posted on Apr 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't get it to work.
I did the set up and it told me to restart and i did now i have no idea what to do. please i need help.
Terry Morrison
Level 2:
  • Expert 53 Answers
  • Posted on Apr 29, 2009
Terry Morrison
Expert
Level 2:
Answers
53
Questions
Helped
32666
Points
122
To view the wireless network connection dialog box, follow these steps:
  1. Click Start, Run, and type ncpa.cpl, and then click Ok.
  2. Right-click the Wireless Network Connection icon, and then choose Properties. (Or you can right click the Wireless Network Connection icon and choose View Available Wireless Networks from the shortcut menu.)
  3. Click the Wireless Networks tab.
  4. Under Available networks, click the View Wireless Networks button.
From the wireless network dialog box, you can refresh the network list. This performs another scan of wireless networks within range. The wireless network connection dialog displays the following for each detected network. The following shows the new connection box.
When the wireless network adapter displays the detected networks, you'll able to select a wireless network name and attempt to connect to it. The antenna icon indicates an infrastructure mode wireless network. The icon that shows two wireless client computers indicates an ad hoc wireless connection.
The lock icon and the "Security-enabled wireless network" label indicate that the wireless network has security enabled. The gold lock means you need a network key in order for you to connect to a wireless network. If it's not security enabled, you'll be able to connect to the network without a network key.
The previous owner of my Toyota gt starlet 1990 had the turbo disconnected to save gas but I want the turbo BK on I'm not to sure how to do it... everything is there as set up but there's something that...
turning turbos off to save gas is a myth as it needs the turbo to work to stop it running very rich
I would suggest that there is more of a problem than what you have been told
try running the fault codes first to get an idea of the list of problems you were not told about
I was told to fix a problem i need to go to start up to search then type in cmd type this netish winsock reset the computer told me to restart6 to finish my computer has restart i do not know what is...
Please clarify: 1. You typed netsh winsock reset on a black screen with a blinking cursor, correct? 2. Then you restarted and the computer is black?
If this is not correct, please tell me the steps you have taken so far.
I can do a test print, but the labels do not print. When I select a label from test print, the paused light gives 0ne blink, then nothing happens
Hello
Thank you for using
FixYa for your problem
you can do a rest print so we know it works, it now why is it working from the program. have you told it to use this printer and maybe you need a tech there to check settings in the program
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
2helpful
2answers
Is it possible to get pictures off crashed hard drive.
Dear
You can still recover your data. Just follow these instructions:
Connect that harddisk to another computer with Windows XP. Check if harddisk is detected on that computer. If yes then check that partitions are showing if yes then simply copy your data.
If partitions are not shown that you have to download software named Get Data Back / RxStudio
And run either of these software to recover your data.
Hope this will help you. May God help you.
2answers
Archos 704 stopped working
A couple of things you can try:
  1. hard reset the 704 using the button under the battery right hand side;
  2. reformat the unit (but that would of course delete contents).
Just curious, did you try/did a firmware update recently? Additionally, the manual has some details on troubleshooting as well as Archos online support.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
11helpful
2answers
Restart sansa e280
Try this: Press and hold the center button and the start button at the same time for about 10-20 sec. it worked for, plus thats what the ppl at sandisk told me to do.
Sansa e270 refresh database
Go under settings and change USB Mode to other choice. Then format. After formatting change back to original setting. I had same prob. Tech support told me to do this and it worked. Have had no problem since.
Canon MP810
Try this Click on start click on run type services.msc a box will open up with listings Check each of the following to see if they are running LexBce Server- should be set to Automactic Print Spooler- Should be set to Automactic Remote Procedure Call(RPC)- Set to Automactic If any of these items are different- change them by double clicking on the line. A box will open up make changes then click apply. Shut down and restart your computer. Hope this helps you
Top Airlink Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
